Alpha N vs. speed density
muythaibxr
I actually wrote some code to test an idea I had about tuning ITB's. I noticed that it was hard to control the AFR with nothing telling the MS engine load at low throttle positions, and I noticed that above about 20-25% throttle position, It was hard to keep the AFRs consistant.... meaning I'd be at 98 kPa, and move the throttle, and while the MAP stayed the same, the AFR would change.
To help fix the problem I saw, I added some code that lets me run a SD table at low throttle positions, and an AN table above that. I have yet to tune it yet though, so I don't know if my idea is good or not.
To answer your question though, most people think it's easier to tune ITB's with alpha-n.
