thermo fan control
pane
thermo fan control
Post by pane »
G'day
I wasn't sure where to put this so i thought it would be safe to ask here.
I'm going to be running ms-2, tfi, ford pwm idle control, lc1 wideband and a relay board.
I want to run twin thermo fans from ms-2 using either pt6 or pt7. How would i connect these to the spare db37 pins when i make my cable to go to the relay board? Which pin on the terminal strip on the relay board will it come out on?
When i change the port settings do i do the following:
port: pt6-iac1
Variable: coolant greater than
Threshold 90 Hysteresis 10
No second condition
Power on value 0
Trigger value 0
Does this sound right. All i need to do is switch a relay on. Is there anything else i would have to do, like add a transistor.
Cheers from aus
Officer, "you were seen doing burnouts in the main street"
"My car cant do burnouts yet"
Officer, "What do you mean by 'yet'"
"Waiting for megasquirt!!!!!!!!"
Officer "oh"
bigdawg
Post by bigdawg »
You might finf whatyour looking for in this thread, hope it helps. I know I will be using it on my electric fan. Good Luck.
http://www.msefi.com/viewtopic.php?t=16572
