Today I read this in this forum:
You need the controller, MegaSquirt (or MS-II) do not have a built-in WBO2 driver at this point.
I didn't know this!
So, If I plan to use a wide band O2 sensor, I MUST buy a WB controller, am I right?
However, the EGO input of MS II (pin 23 of DB37) supports a signal from 0 to 5 V, so MS II can "read" the signal from a WB EGO sensor but this signal is unusable(but viewable with megatune?)?
Am I right?
