Iam putting a MSII Ver 3.0 together and Iam little confused on FIDLE setting.
So if Iam wiring into a two wire IAC valve. Do I use the TIP 120-122 transistor? I guess Iam confused where I put the Transistor on the board?
And what wire is it on the DB37?(is it one of the Stepper Outputs?)
In Help would be Awesome!
Thanks!!!!
for fidle (used on old cis injected engines) u dont need to replace any transistors. u need relay to switch it on/off (actually , when engine warms up and ur fidle module is bolted to engine , it will close anyway)
for pwm idle (on newer european engines , bosch two wire pwm idle valve)
u need to use TIP transistor and pwm idle valve will connect to same pin as fidle usually connects (directly , without realy)
