EDIS CTO signal - scoped
shauer
I just got my MSII with EDIS up and running ignition only for the time being. When I first tested EDIS w/o MS connected my tach worked fine using the CTO (EDIS pin 11) signal to drive my VDO tach. When I hooked up MS I got a good RPM signal in MegaTune but my tach stopped working. In the process of bringing up the EDIS functionality I enabled multispark and my tach started working again at idle but would stop working around 1500 RPM.
I put my scope on the CTO signal and found that I had a nice clean square wave of about 13 volts but I found that the pulse width changed. Here is what I measured:
- With MS disconnected, CTO pulse width was 1.0ms
- With MS connected, W/O multispark. CTO pulse width was 500us
- With MS multispark, multispark CTO pulse width was 1.0ms
- With MS multispark, higher RPM (non multispark) CTO pulse width was 500us
It seems pretty obvious to me that my VDO tach works fine with the wider 1ms pulses from CTO but the shorter 500us pulses are too short to trigger the tach.
Has anyone else observed this? I'm planning on backing into a schematic of my VDO tach to see if there is an R/C filter I can modify to make it sensitive to the 500us pulses.
1977 BMW 320i
MS II V3 mainboard, v2.36 firmware, EDIS4
Megatune v2.25
Mike Simard
shauer
I traced my tach input circuit and found a two stage r/c filter going to the input of what I'm assuming is a 555 timer IC. I simply reduced the R values to about 1/3 of the original value and the tach is working great.
I know several people on the board have fixed their tachs the same way, I was just surprised to see the different pulse widths on the CTO line.
1977 BMW 320i
Megatune v2.25
