OEM plugs and router board question
ISC300
Post by ISC300 »
First of all, i want to say Hi to all of you and thanx for having this forum. I"ve been doing research about the Megasquirt and will be purcharsing one soon .It will be Megasquirt II v.3 to start off with, I'm considering buying all other "add-on board" that needed to make it work. I was looking in to the Router board on here http://www.megasquirt.info/router/ but where I can get it? is it out yet? from what I read from the website, it will have SS Injection and coil on plug feature . i will use this unit on my 95 non turbo Supra 2JZ-GE ,so it will be a distrubutor , but I want to convert to Distrubless C-O-P setup , I think Router board is what I need right I might need the crank (teeth)wheel and crank sensor? correct me if I"m wrong. I will use seperate wire instead of cutting stock harness so I am thinking to get some OEM plug "connector" or harness ? I need them so that I can plug it back to the stock sensor ( IAC ) ( Water Temp ) .....etc....
My main purpose of converting distrubutor to C-O-P is because I think it's more reliable for high HP , but I have seen alot of sucess with Distrubutor but it's just my personal thing, I turst C-O-P more than other ingition setup , on top of that It will look nicer.
My car orginallly is OBD I so they will be running my car on a dyno with the exhuast thingy hook up , how many of you passed Tx inspection with Mega squirt II ?
Anyone doing the MS on their 2JZ-GE motor?
ISC300,
Check this for an update on the router board: http://www.msefi.com/viewtopic.php?t=15011
(scroll ½ way down the page)
