FIDLE VAVLE AND RELAY BOARD
themaintenanceshoppe
Post by themaintenanceshoppe »
MS1 V3 WITH RELAY BOARD. I PLAN TO USE A SOLENID VALVE FOR IDLE AIR CONTROL AND WAS WANDERING IF 1 OF THE 3 RELAYS ON THE BOARD CONTROLS THIS. I'M JUST TRYIN TO FIND OUT THE AMPERAGE LIMTS FOR THAT CIRCUIT.
keithmac
Post by keithmac »
There`s a fidle relay on the relay board, if you want to drive an ISV from the fidle pin you need to upgrade the transistor on the MS circuit board.
Squirted VW GTI 16vG60 mk2
