can I get these to idle right?
When I had a Holley TBI, it had 4 85 lb/hr injectors on a 6.7 liter engine. The idle was around 1.7 milliseconds and 35 kPa. However, 1.7 milliseconds at idle is borderline.
Your engne is 64% as large, but only has half as many injectors, so that's good. On the other hand, if it is stock it might idle with a lower vacuum kPa. I'd say that it will work, but not perfectly with MS-I.
MS-II has 100x the pulse width resolution, so it would be a better match, and should be fine. For example, I have 8 72 lb/hr injectors on my engine now with MS-II, and idle isn't a problem at all.
