Nissan injectors not QUITE high impedance ie 10 ohms?
1) max current that can be sourced per injector bank (mm says to try to keep it around 1 amp, current config would be around 4 amps!)
2) should I use resistors or PWM to limit the current?
This is for a v6, 3 injectors per bank.
Thanks!
94 Probe GT custom headers/ short ram intake/282dur cams/modded intake
147wtq@6800/197whp@7700rpms
