idlecontrol
Posted: Fri Jan 13, 2006 9:34 am
by streetknight
how would i go about controlling idle with ms? i know that on bmw e30's its controled by the motroc, but if i am controling fuel how would i go around it.?
Posted: Fri Jan 13, 2006 10:09 am
by natesully
If you are doing fuel only, let the stock computer take care of it. Else, figure out what kind of valve it is (PWM variable idle, stepper motor variable idle, on/off, or some BMW crazy valve) and we can go from there.
Posted: Fri Jan 13, 2006 2:20 pm
by streetknight
Posted: Tue Jan 17, 2006 6:46 pm
by mops
it's a 3 wire PWM IAC valve. works really, well, but you need to construct circuit to drive ir correcntly. once you have that you can very precisely control idle air across wery wide range :)
Posted: Wed Jan 18, 2006 3:14 am
by streetknight
i think mines is 2 wire set up. ill check tonight. what board would i have to make can u give me a site or a starting point?
