idlecontrol
streetknight
idlecontrol
Post by streetknight »
how would i go about controlling idle with ms? i know that on bmw e30's its controled by the motroc, but if i am controling fuel how would i go around it.?
natesully
Post by natesully »
If you are doing fuel only, let the stock computer take care of it. Else, figure out what kind of valve it is (PWM variable idle, stepper motor variable idle, on/off, or some BMW crazy valve) and we can go from there.
95 Miata M-Edition, GT28 Turbo
streetknight
mops
Post by mops »
it's a 3 wire PWM IAC valve. works really, well, but you need to construct circuit to drive ir correcntly. once you have that you can very precisely control idle air across wery wide range :)
streetknight
i think mines is 2 wire set up. ill check tonight. what board would i have to make can u give me a site or a starting point?
