Page 2 of 2
Re: Please help!!!
Posted: Fri Dec 23, 2011 9:43 pm
There was a problem with the injector outputs in the code for this non-wheel, non-dual spark mode. I have attached a corrected code version, v3.780 and ini file. All inputs are the same so the only ini file change was in the code version number. There is nothing in the new code that will change anything for those with toothed wheels and dual spark mode, so there is no reason for those people to update.
When I first tried the new code fuel still didn't work. This I traced to an incorrect setting in your msq - you have the lower and upper Rev Limit rpms set to 5500 and 500, so that is killing fuel above 500 rpm. When I corrected this in the msq the problem went away. You will also need to correct this if you use 2.905 code.
