Engine dies around 4500 rpm
Blue
Re: Engine dies around 4500 rpm
Post by Blue »
Here are more scope images with the MicroSquirt at 3,000, 3500, and 4000 RPM at 1ms, 20V/ div.
Blue
Post by Blue »
submitted in error. Please disregard.
Blue
Post by Blue »
Here are scope traces at 4300 RPM, 1ms, 20V/div, and 1500 and 2000RPM, 5ms, 20V/div
Blue
Post by Blue »
Here are scope traces at 2500, 3000, and 3500RPM, 5ms, 20V/div
Blue
Post by Blue »
Here are the last of the scope traces with the MicroSquirt controller at 4000 and 4300 RPM, 5ms, 20V/div
Blue
Post by Blue »
Here are scope traces using the stock Chrysler controller at 800 and 4000 RPM, 2ms and 10V/div
Blue
Post by Blue »
Here is the amended ve table that I was using last night. I made a mistake with the data log, and the file doesn't contain the test run that I thought it did. I'll try to get another one tonight and post it later.
veTable 4-16-08.vex
(1.63 KiB) Downloaded 96 times
Blue
Post by Blue »
Here is a datalog file using the ve table I posted earlier today. It shows the lean condition starting around 4000 RPM that seems to persist regardless how rich I make the ve table in that region.
I'm open to any and all suggestions.
Thanks.
4-17-08 datalog.xls
(135.26 KiB) Downloaded 93 times
Blue
Post by Blue »
Is there a Stimultor for the MicroSquirt controllers? If not, could I adapt the MegaSquirt Stimulator to work with a MicroSquirt? If I could set up my controller on the bench with a standard set of inputs and loads from the Stimulator, that might give me some clues that would get me closer to a solution.
Does this sound like a good idea? Are there more things I should be trying with the controller still in the car?
Bruce and I are at the Megasquirt Meeting. As soon as Bruce has time he will look at the traces. I haven't really seen any fueling problems in ages, so I'm not sure what to say. Give us some time to think about this. Also, please post your msq. The stim can be made to work with microsquirt, but you would have to work out the wiring.
