Posted: Fri Jun 02, 2006 2:20 pm
I can adjust PMW% but there isn't a difference in idle or afr's by going up or down. I can set it at 1%, 30% or 100% then try and change the Opening Time/Time Threshold. Doesn't matter what the % is set at, the lowest I can get the Opening Time and not have it instantly stall is 1.2. I have tried 1.0 with various % settings and then try changing the VE up but it still won't run. On Auto Tune I can lean it out or richen it up as far as I can and save it but it doesn't change the afr's.
