V3.0 circuit clarification requested.
MurrayA4
In this circuit, transistor Q2 provides ground for the pump when the processor provides voltage through FP-1 and R16.What is the function of transistor Q19 ? The zenor diode D4 is there simply to protect against voltage spikes from the pump circuit.(Correct?)
Once I can fully understand this circuit I'll feel better about modding it to provide +12V to the pump which is required due to the requirements of my Bosch injection system (currently L-Jet)
jsmcortina
- MegaSquirt Guru
My pump requires a 12v supply and I use the standard fuel pump transistor circuit. A relay must always be used anyway as the puny transistor could never supply enough current for the pump.
MurrayA4
The schematic below demonstrates the fix for the older board,now I'm attempting to mimic its logic on the V3 driver circuit.
