Small injector, about 9lbs per hour
the bubbler
Any suggections for a donor for such a small injector?
The Honda pantheon scooter looks a good bet, but these are difficult to find (well, impossible) in bike breakers, as they are very new.
Any suggections?
Andy
Using the calculator in the MegaManual, these will squirt about what you need at 20-25ish psig of fuel pressure. Depending on the application and injector placement this could work well. We are running a D16 Honda with only 16-18 psi fuel to oversize injectors with no ill side-effects.
Hope that helps,
David
the bubbler
Finally, if you pick-up one of the potential injectors and test it with varying pressure with a suitable fluid (mineral spirits works well) you can check the spray pattern and atomization for yourself and determine if it's what you want or need.
All of the answers you get will mean different things depending on the big question: What is the goal of this EFI project?
David
the bubbler
The engine is for a small BMW Isetta bubble car.
Original equipment is a small piston valved Bing carb with a 22mm choke, ignition is points based with mechanical centrifugal advance.
The engine produces 13bhp and about 14 lbs per ft of torque.
I would like to improve drivability of the car using more sophisticated fueling and mapped ignition, and also improve the torque figure so that I can pull a taller final drive easily.
Andy
