Finding an Inject that meets my needs
njciscool
Post by njciscool »
Hi, this is my first post on this board! i've lurked for a while, and havent seen anything posted that helps me out with my question.
anyway, i've got a 620 hp big block chevy in the works right now, and was wanting to try fuel injection on it. I sized the injectors using the calculator, and it says i need 44 in jectors, as I'm running port injection.
Anyway, since I need an 80% duty cycle, I actually need 55 injectors (is it 55 lbs/hr or gph?)
anyway,is there a table or list of injectors that flow a certain amount? if not, it seems someone should make one... maybe i will once i know more about this stuff!
thanks a lot
Nick
