I've been in the engine business many years, but more in the mechanical and stock electrical Side, and never installed a Microsquirt before. Now I'm about till install a Microsquirt v3 on a 60degree twin cylinder motorcycle engine. The stock distrubutor is a VR sensor. As we all know, this gives an AC voltage. In the manual I red that this needed to be transformed into a square and positive curve by a ignition module. My question is if this transformation is done by the microsquirt itself or if I need a additional ignition module to make the MS Accept the signals? In Short, can I connect the VR sensor with AC voltage directlly into the VR+/- cables in the MS?
Next question; this engine has coil-on-plug coils with a 4-pol connector. I never worked with such things before, only regular primary/secondary coils and spark plug caps. I red in the manual about LS1/LS2 coils and all this. But it was written that I need to find out if the coil has a ingiter, which dwell that is appropriate and off course, which pin is which.
I have absolutely no documentation of this engine, and no knowleague about coil-on-plug. So this question might be very stupid. Can I somehow measure or find out if my coils has a igniter? Or does all coil-on-plug have a igniter? Can I somehow measure or find out which pin on the coil that is which, preferably without hooking up or tearing up the stock ignition system again (measurements on the 4 pins of the coil)?
About the dwell I found in the manual how to do if the dwell was unknown.
I hope someone with more experiance can answer My questions, or point me in the right direction.
Thanks guys!
