loss of comm after engine starts
racincrj
lost communication on start up
Post by racincrj »
okay i am stumped. everything works fine until i start the engine i get good cranking rpm and for a brief second i get running rpm then i lose communication the bike stays running. after this happens i have to shut off the bike unplug my usb cable and plug it back in to reconnect. i am running a microsquirt v3.77 code and tuner studio ms lite v2.505 i have previously used this laptop and data cable on a megasquirt2 with no such problem. any help would be awsome!
Curtis
racincrj
Re: lost communication on start up
Post by racincrj »
update i was hooked directly from microsquirt rs232 cable to usb adapter cable. added rs232 cable from last megasquirt project. and walla! :D however i am still a little confused? sometimes it will still drop the comunication.
racincrj
Post by racincrj »
I am stumped! What's going on is when the engine starts and runs I lose comm at first I was hooked up directly from microsquit rs232 cable to USB adapter. Everything was fine until engine started the I would lose comm. I added the rs232 cable from a previous megasquirt and it would run for a while then lose comm after making the cord as straight as possible and moving the laptop as far away from the bike as possible it now seems to communicate with no problem! I am running 4 ls2 coils wired in parallel for a waste spark set up I have the recommended capacitors. It runs really good! But I am worried that maybe this is causing a lot of noise? Causing the loss of comm? I eventually would like to run a wireless set up but I would imagine that may be a major problem! Any thoughts or ideas would be greatly appreciated!
Curtis
Re: loss of comm after engine starts
USB is a fairly 'fragile' protocol, and is meant for a desk-top environment. In a noisy environment, RS232 right to the laptop and then a VERY short USB connection will help. Bluetooth might work, as it is meant for a 'real-world' environment.
That says to me that you're firing all four each time, every time - really?
racincrj
Post by racincrj »
i am sorry i didnt state that correctly! i have two banks of two coils wired in parallel. i new after i posted it i would get checked on it :oops: but that is good news because i plan on going wireless soon! thank you so much for the input!
Curtis
Are you running non-resistor spark plugs by any chance?
racincrj
Post by racincrj »
it turns out i was useing non resistor plugs. i am a auto tech and havent seen non resistor plugs in a long time. it is a old motorcycle and i didnt even think about it. :oops: i am running ls2 coils in waste spark configuration. i will have to do some research as to a suitable replacement spark plug. but it makes perfect sense that thats causing alot of noise. i was sure i had wired everthing as per recomendation. thank you so much for your input!
They are pretty rare, but having trouble when you do have them is pretty common. :) Glad to hear it's resolved.
