VR Conditioning Board??
Thanks.
- Master Squirter
Re: VR Conditioning Board??
I don't think I am being critical if I say that there is a conditioning problem with the shared or common ground when using a VR2 cam sensor, as well as the threshold voltage seemingly being too high to detect, in my case, the cam lobe.
The newer almost released v3 MicroSquirt has a revised conditioning circuit based on a MAX9926 chip, and a wiring change at the Ampseal (pin20), to create a separate VR- input. These two changes hugely enhance the conditioning circuit, and transform the VR sensing capabilities of the MicroSquirt.
If you are going down the crank & cam sensor (VR1 & VR2) input, and have the older MicroSquirt, I personally would recommend a VR conditioning board based on the same MAX9926 chip that the v3 uses, as this simplifies and eradicates nearly all the issues I have seen in four years of playing with MicroSquirts on motorcycles. You can make your own, or buy one from here, which I have done a couple of times, and all the board does is process the raw signals from your sensors, cleans them up etc and then you interface these outputs into your Microsquirt. You don't interface the HEI with the VR conditioning board.
The added advantage of these MAX99xx chips is they can easily discriminate false triggers from noise, which can help at higher RPMs too.
Hope this helps.
PS If you are just using a crank sensor with a missing tooth wheel, it is not necessary to use an additional board/circuit, and if you need a cam sensor (sequential etc) some folks have successfully used a Hall sensor for the cam input, because these can easily overcome the 1.8V threshold voltage limit, as generally they use 5V or 12V DC.
- Master Squirter
So for example in my 4 cylinder engine, using the 2 Logic Level Outputs in wasted spark mode for a 1342 firing order with my external ignition module, I have IGN1 tied to 1&4, and IGN2 tied to 2&3 cylinders.
After rereading the end of your last post you had mentioned if using just a crank sensor I wouldnt need the board. I had planned on using a hall sensor for the cam sensor from the beginning. So with a VR sensor on the crank and a hall sensor on the cam I wouldnt really need the VR conditioning board after all? Unless I went VR on the cam also?
- Master Squirter
Yessn95.ohh wrote:...So with a VR sensor on the crank and a hall sensor on the cam I wouldnt really need the VR conditioning board after all? Unless I went VR on the cam also?
