any update?
chango de naranjito
Re: any update?
chango de naranjito
Re: any update?
how's the testing? and the VR sensor chip works ok in the test cars?grippo wrote:I hope so. We finally have a batch of new Sequencers in hand and the new hardware on it - a new power supply and a new dual channel VR sensor processing chip - both test out ok on the bench. I was able to start up a Sequencer with normal battery voltage, then turn the volts down from 12V to *** 3V *** and it kept on running. You won't be able to go down this far with a real engine, but that will be because the injectors won't open, not because of the ECU. The VR sensor chip also works, but we won't know how much of an improvement until we test it on many real engines.chango de naranjito wrote:how is the sequenser going? can I buy one this year?
So, depending on how well continued testing goes, we should be able to send some to beta testers in a few weeks.
Re: any update?
As soon as 1 more engine is running I will look for more testers.
Re: any update?
Re: any update?
Yes, but its prognosis is looking good at this time; we'll probably be able to discharge it from the hospital soon. There are a number up and running. We've got one ourselves that is going to be installed on a Nippondenso DIS system, one that's been known for noise issues. Figure it'll give the MAX9926 circuit a good workout.sheriff wrote:is the sequencer still on life support? looking forward to installing it on my truck. thks jim
Peter Florance
Re: any update?
Peter Florance
Re: any update?
I'll let Al explain the differences but it is much easier to set up and it runs very very well.
I'm impressed with the performance of the sequencer.
Peter Florance
Re: any update?
Very smooth.
Peter Florance
Re: any update?
Runs well enough I just left it in and autocrossed with it.
Peter Florance
Re: any update?
Note sure when more will be available.
