Aaron, you been busy from all your posts. Voltages do seem high vs rpm compared to say my bikes, so you must have a high gain sensor, and I have seen Bruce's post.
I used some small diameter resistors, approx 3mm diameter (electrical isn't my area), placed them inline, and they reduced the p-p voltage.
Aaron Silidker wrote:...not knowing the exact gap between the flywheel and the sensor (I ran it nearly touching on the lathe) would be close to 600 volts!!! When I backprobed the connector when the bike was stock before I modified the flywheel and the bike was running, at roughly 10k RPM I saw a peak to peak of around 200+ volts. The scope I was using sucked, so the peak to peak values were wild. I will assume I have a decent sized gap when the engine is assembled. I have no good way to accurately measure the gap, so I made my teeth on my wheel the same height as the teeth on the stock flywheel. At least I know in that case I will not be hitting anything....
I don't know if you are aware of this, but you can also reduce the p-p voltages by increasing the air gap.
Aaron Silidker wrote:Finally, how does the general shape of my signal appear to you? Is it very clean, or typical?
Looks clean to me as a raw VR trace, typical shape... as you'd expect.
