"1983 BMW R100RT bike being turboed, injected, photo's will accompany that point in the project that she's out of the workshop and into the garage again".
OK - so its not just a casual observer cluttering the post ways.
I observe pro's and con's relative to driving the ignition coil directly, or with external module, and fail to see the best percentage.
One post will say it is definately worth "not doing" , another claims it is part of the micro squirt and works just fine. Then it is stated that the tach signal "interruptions" occur within the box and this causes one to ponder if the interruption develops on the external wiring and chases inside, or takes place within "despite your best house/keeping efforts" at properly sheilded and separated wiring.
If I could gain clarity on the two methods in the following questions:
WHEN YOU DIRECTLY DRIVE COIL(S):
-The capacitors mentioned (0.01microFarad @ 630v etc.) are giving me a bit of challenge to locate exactly and I tend to frequent the automotive supply stores more than electronic supply houses so , can I just use one of the old Ketering or points style of capacitors instead? (3.0ohm dual output "Dynatek Green" coil presently on the project).
WHEN YOU DRIVE WITH EXTERNAL MODULE:
-Sounds like changes are required for the Micro Squirt such as either
a) "Logic Level Signal" modification by removal of the VB921's and adding the appropriate Bosch type module.
or
b) Addition of the 4.7k resistor from Vref to IGN output -HVc, etc.
I see significant factors on each side of the fence, I'd be obligated in a serious way if Squirters that have "been here & done that" before might post a comment to help aid in this decision.
Thanks in advance, any comment valued.
