M-0 Wheel
Re: M-0 Wheel
I understand what you're saying, and it makes a lot of sense. But couldn't this problem be avoided by using the "Falling edge" instead of "Rising Edge" or vise versa, or am I not understanding this option correctly?
How would I go about putting a bias of .5 or 1 volt into the signal?
Kyle
Re: M-0 Wheel
Now remember I am not saying with certainty that this is the problem, it could be your configuration (msq), or many other things.
I don't know off the top of my head what resistors to change, but there is an extensive writeup about it in the megamanual or at microsquirt.info. Bruce also posted some stickys.
Bruce Bowling
- Site Admin
Re: M-0 Wheel
You can very easily introduce a bias. Take a diode, like a 1N4003 or similar, and put it inline with the VR+ signal. In other words, disconnect the VR signal from the VR1+ input on MicroSquirt and introduce the diode in series. Have the band end of the diode point toward the VR sensor (away from the VR1+ uS input). What this does is introduce a -0.6 volt drop in the circuit, meaning that the input waveform will have to go 0.6 more negative for the same output response (compared to the un-mod circuit). If one is not enough then add another diode in series (band also pointing towards the sensor) this will increase the drop to 1.2v or so.Kyle R wrote: How would I go about putting a bias of .5 or 1 volt into the signal?
Test this with first the single crankwheel mode like you did earlier, and make sure there is a stable cranking RPM.
Re: M-0 Wheel
Here is the MSQ file that we got off the microsquirt. If anyone could take a look and see if anything is obviously wrong, we'd appreciate that.
We also did some data logging tonight, here is one of our cranking attempts. We've also had it where we get one intermittent tach pulse and trigger, we are going to try to reproduce that tomorrow as well.
Kyle
- Attachments
- test1.xls
- (53.66 KiB) Downloaded 71 times
- SCSU12208.msq
- (25.18 KiB) Downloaded 74 times
Re: M-0 Wheel
With this diode in place, will the signal get messy at higher rpm? The engine will spin about 11,000 RPM
Kyle
Re: M-0 Wheel
Bruce Bowling
- Site Admin
Re: M-0 Wheel
The diode addition should not affect high RPM operation, unless, like Al indicates, the flat spot jitter peaks expands into the offset region. I would suspect not, the 0.6V offset should be enough to keep you safe, but the final say is when you push to the 11K point...Kyle R wrote:We put the diode in place and it seemed to fix the problem, so hopefully we can get it running this afternoon.
Kyle
UMainePhaze09
Re: M-0 Wheel
Unlike Kyle, our cam sensor ouput is not square. We looked at it with an oscilloscope, and it appears to ramp up from zero, then fall suddenly. Since its the same snowmobile, we're not sure why it looks different. We are assuming that this is the problem. Is there anyway to transform the signal so that it is square, or is it a problem with the sensor? Any other suggestions would be greatly appreciated!
Re: M-0 Wheel
I have had some success with this exact setup, I'll PM you some ideas.
Geoff
SQLGUY
- Experienced Squirter
Re: M-0 Wheel
Here's what the signal from my VR sensor looks like (or at least looked like with a previous, working, 8-1 trigger wheel):
In this case, IIRC, I had some 12V zeners clipping the signal, so it normally would have been pointier. Notice that the rising edge here makes the better trigger point, since it crosses zero more vertically than the falling edge. In some cases you may need to reverse the mechanical polarity of the sensor (switch the VR+ and VR- lines) in order for uS's bias to best condition your signal for zero crossing detection.
If you don't have a scope, you might want to drag in someone from the EE dept and show them the VR portion of the schematics.
