Intermittent Stalling
The problem is that often times while idling uS will just quit. This has happened while I had my laptop connected and I observed that the tach signal and pulse width simultaneously dropped to zero. The datalog from my LM1 clearly showed that the AFR went dead lean before the MSD stopped producing a tach signal indicating to me that uS is to blame.
Wiring is not an issue nor is the power supply, switches, etc. My uS is one of the orginal ten units that DIY Autotune sold when uS was released last year. The only updates I have made have been the VR diode and the bootloader wire is now tied to the 5v reference voltage through a 10k resistor. Both mods were made mere minutes ago based on what I have read on the message boards and neither helped or worsened the problem.
Another issue I'm having is that the motor will not rev past 5000 rpm or so immediately after starting the engine whether the engine is hot or cold. When the tach gets to 5000 rpm or so, it bounces wildly while the engine goes into a rythmic surging like you would get with a slow rev limiter. This goes away after 20-30 seconds of idling before hitting the throttle. I'm not real concerned about this second issue as it might just be a tuning issue. Maybe an overly rich after-start setting.
Any help or suggestions would be welcome. I have an exhibition race at Norwalk, Oh (10/11-12) and would really like to have this fixed by then.
Thanks in advance.
Tires warmed and engines stressed while you wait...call for an appointment...
Re: Intermittent Stalling
SQLGUY
- Experienced Squirter
I didn't know you could do that. When I've captured a datalog, it always included all the data points, and it was in MegaLog Viewer that I was able to select which values to view.DoD70 wrote: AFR and RPM were the only channels that were recording at the time and I was watching the gauges on Megatune when it stalled.
Can you post the log(s) anyway?
- Attachments
- datalog200810022115.xls
- Surge & Stall Datalog
- (41.6 KiB) Downloaded 94 times
- Attachments
- Toothed Wheel Base.msq
- Toothed Wheel 1.0
- (24.89 KiB) Downloaded 87 times
I noticed while I hade my laptop hooked up to uS and had Megatune running, that the accel button on the bottom of the Megatune main screen flickers while the car is idling. Can it be that uS is adding fuel for acceleration while the motor is idling in sufficient quantity that it floods ands stalls the motor? If so, would that not be reflected in the O2 graph? When it does stall, it does so without warning. Just as if you shut the motor off with the main power switch.
Going back out for more test and tune tomorrow. Then I'll just have to go to Ohio with it like it is.
