Main Relay Clicking On + Off ????
I'm running a Microsquirt on a 4 cylinder 4 stroke motorcycle engine. I am also using a relay board.
I had finished up all of the wiring, triple checked it, and I have a problem.
When I apply power to the switched 12v source wire, the main relay clicks on for approximately a second and then clicks off. When I disconnect the harness wiring between the Relay Board and the Mircosquirt, the relay stays energized.
Any ideas? Any suggestions for diagnosing the problem?
Thanks again.
DW
SQLGUY
- Experienced Squirter
Re: Main Relay Clicking On + Off ????
The fuel pump relay is supposed to click on for about one second when Microsquirt is initially powered up. This is to pressurize the fuel line/rail for the priming pulse. After that, it switches off until Microsquirt detects cranking.
When using the port checker program I get the following message
COM1 Opened
9600 baud
No connection made.
115200 baud
No connection made.
1 valid port found.
Hit return when done....
I have also tried the communication testing section of Megatune with the same results.
I am using a serial com port on my laptop. I have checked the port on the laptop and it is fine.
I have checked the power supply and grounds for the Microsquirt and they are fine.
I am using the 2.886 code and have set the "interWriteDelay = 5"
I have set Megatune as "2" which represents Microsquirt.
I have read and reread the Megasquirt Connection Troubleshooting Guide and performed all of the tests and everything is correct except I still can't communication with Mircrosquirt.
Any thoughts or suggestions?
Thanks again everyone for the help. I'm looking forward to completing this project.
DW
Sure enough I had a bad serial cable. I bought the cable with the Microsquirt, but as you find sometimes, NEW does not mean GOOD. ;-)Matt Cramer wrote:Check your serial cable to make sure it's OK.
I made a cable myself and now I can get responses from Hyperterminal and Miniterm (through Megatune), but I still can't get a connection through the communications screen in Megatune. "No response" is what happens when I test the connection.
In Megatune under "General" I have set the number to "2" representing Mircosquirt so at this point I am stumped.
What am I doing wrong?
Thanks again for all of the help.
DW
I have the latest version of MS loaded into Megatune which is 2.886. I have rechecked all of my wiring, tested my new serial cable, and verified I have all the software loaded and configured correctly.
So tonight I decided to try to upload 2.886 into Microsquirt in case for some weird reason it did not have the correct code loaded on it when I bought it. I followed the manual to the letter and after watching a lot of code flash by on the downloader program the follow error was at the end of the process.
I would appreciate any help you can give me or a direction to head.
Thanks in advance everyone.
DW
Matt,Matt Cramer wrote:You mentioned you could get a response in MiniTerm. Can you post a screen shot of that?
Thank you for your help.
Below is the miniterm screen shot and also the communications settings screenshot.
Any suggestions?
DW
- Attachments
- miniterm copy.jpg (29.11 KiB) Viewed 1633 times
- failed copy.jpg (33.68 KiB) Viewed 1633 times
