Wideband 02 Sensor Wiring
1979-mini
MegaScott
- MegaSquirt Guru
Have you looked at the JAW controller? I've got one running one my truck using Megasquirt and it seems to work just fine with the latest High res output table emulating the LC-1. Click here for the JAW web site
MegaScott
- MegaSquirt Guru
The Microsquirt is really just a miniature MSV3 and MS2 all on one small board, with the exception of the Vr circuits, lack of injector PWM and one additional ignition output channel, the Microsquirt O2 input is the same as any other Megasquirt.1979-mini wrote:MegaScott,
The Jaw controller looks perfect. That's what I was looking for. I think it'll do the job. I assume Microsquirt can read the JAW output without any issues...
In the JAW download site you need to download and burn the latest firmware. Then run the JAW edit software on your PC and program it for the LC-1 defaults on the channel you are hooking to the Megasquirt. Then setup the Megasquirt for the LC-1 widband controller and your golden.
