lost communication with Microsquirt
Something else you might try is the loopback test (to see if the serial port is still working). To do this, you jumper pins 2 and 3 on the cable end, and use hyperterminal (or mini-terminal under Communications in MegaTune, this is much easier) to see if characters you type are echo'd. There's more on this in steps 26.a) to 26.e) here:
http://www.megamanual.com/ms2/V3assemble.htm#serial
Bruce Bowling
- Site Admin
Email me your address (send to bbowling@earthlink.net). I will email you a few other things to try...ofredo wrote:still can not access bootloader mode, no communication what so ever.
unit has 5 volts at ref. wire
