As the topic says.. Has anyone found a configuration that gives factory style starts? I'll explain, when I start my Megasquirted car (see sig) I have the IAC cranking set so it will have enough air supply to fire without any pedal assistance when hot/cold BUT, when the engine is hot, the car will fast idle for the set hysteresis time then IAC slams shut. Now tonight driving our 305TPI Trans Am I noticed that when starting it will open the IAC on a hot start and taper off/close for a duration of about 2-3 seconds and not just suddenly slam shut. At the moment my megasquirted car will fire up very easy but once it fires it'll fast idle at about 1100rpm for, I think I set it for, 5 seconds then drop down to 800rpm with no crank to run taper. Anyone got any input as the physical time I have to test/trial is very limited due to work commitments and can't experiment of a night after work due to the noise of the car
Cheers Kris
Sydney, Australia Successfully MS2 v3.0 squirted 1971 Holden Monaro HQ 400 Pontiac, ported #16 heads, Tomahawk intake with custom plenum using LS1 78mm throttle body dialed in with a TechEdge 2E0 Wideband Controller.
-------------------- m2f -------------------- This post is at:
http://www.msefi.com/viewtopic.php?p=135623#135623 -------------------- m2f --------------------
Posted by email.
