Niose On Coolant Temp And Air Temp?
quattrodave
Post by quattrodave »
Hiya,
Just been going through a log and i noticed that i appear to have noise on the coolant temp and air temp. Could somone confirm this?
If it is noise, how would i go about solving it?? I'm using MS 2 V3 with the recomended GM sensors.
Many thanks
Dave
5 Cylinder 10 Valve Turbo :-D
mops
Post by mops »
what I noticed is that both CLT and MAT is heveily dependent on battery volrage. if you have spikes there you will have spikes in temp readings. and temp sensors should be grounded to main ms ground for stable readouts. It is absolutely crucial.
BottleFed70
Post by BottleFed70 »
I took a look at the datalog and if it is noise then it's only effecting your temp readings by less than 2* (less than 1* in most cases).
This is so minor I wouldn't even bother worrying about it..
1970 Ford Mustang
mops
Post by mops »
well, I looked at my datalogs, and at 14V MAT reading is ok, while at 10V (durning cranking) MAT reading shows about 20 deg C more. When i plotted the batt and MAT graph on one screen that I noticed very strong corelation between two.
just my .02
BottleFed70
mops wrote:well, I looked at my datalogs, and at 14V MAT reading is ok, while at 10V (durning cranking) MAT reading shows about 20 deg C more. When i plotted the batt and MAT graph on one screen that I noticed very strong corelation between two.
just my .02
Hmm.. interesting findings. If I understand the temperature circuits correctly they use a 5V reference provided by the voltage regulator. In theory you should not see any problems until battery voltage drops below 6V.
1970 Ford Mustang
quattrodave
Nice one cheers guys for the input.
Dave
