aem wideband
elturbonitroso
aem wideband
Post by elturbonitroso »
Hi guys i just got my aem wideband p/n 30-4100 and i have a ? in megatune i have to set it as aem linear and my other ? is do i have to put the 370 ohms resistor like the innovate lc-1.thanks
User avatar
460stang
Post by 460stang »
I am running an AEM unit. Not sure of the part number but it is the one with the controller built into the gauge.
I am not using any additional resistors. Is working very well.
elturbonitroso
thats the one that i have so the reading in megatune and the aem is exacly the sames how you set it up in megatune as a aem linear.
elturbonitroso
i set up mine as AEM wideband linear and when i open megatune give me a warning that said no 02 sensor configuration anybody with any idea im using a ms1 v2.2 code 024s13 and megatune 2.25
elturbonitroso
anybody with some advices
tapedshoes
Post by tapedshoes »
i have the same wideband methinks, but it uses the same voltage output as an innovate wideband. Dont set it as an aem wideband linear in your settings, set it as an innovate 0-5. Then go into lambda settings ini and look for the innovate 0-5 setting. change any "10" to a 9.5, as MS will read the AEM .5 points off otherwise. hope this makes sense
elturbonitroso
ok i do the change in the configurator as innovative lc1 and i dont get the error.
