When tuning initially, how do you set AE?
ochizon
Post by ochizon »
Do you set it completely to zero?
efahl
Site Admin
Post by efahl »
Sort of. You want to disable it completely, and the easy, one-number way to do that is to set the trigger threshold to some artificially huge number so it simply never happens. Normally the trigger threshold is in the 1-3 v/s (20-50%/s) range, just set it to 50 v/s or whatever is the max value you can type in there.
Eric
