MSII V3 Build Questions
BTW-Orderd from DIYAutoTune, great service, great packaging.
It was probably available but I didn't see the sockets or Q4 option for PWM IAC valve.
Anyway:
Question 1:
Step 22 on the V3 assembly instructions:
I am planning to use a PWM IAC as mentioned above. But if I change later to a Stepper Motor type, will I have access to the jumper locations?
Will it be ok to install the jumpers now to get signals to DB37?
I know there are other mods involved to get back to stepper motor capability.
Question 2:
In building a wiring harness. What gage wire is recommended?
Current under the hood instruments appear to be about 18g.
I can't see getting the DB37 loaded up with 18g wires, and DB37 appears to be something less than 18g itself.
PS; Having a great time with this project. The Stimulator is completed.
Going to the "Shack" to get some IC sockets.
I recently built my v3 board, and I went the stepper IAC route. I think if you were to switch from PWM to stepper at a later date, you could just desolder the PWM components and put on the stepper components. Shouldn't be a big deal.
For question #2, I would use 20 gauge for sensors, and 18 gauge for things like injectors. Fuel pump circuit will of course have to take a larger wire. If possible, try and get wire with insulation on it that is rated for engine compartment temps. I was able to get an engine harness in decent condition that I stripped down and used to make my own harness. That way I had the right wire type.
-Patrick-
'04 SRT4 - Daily driver
Philip Lochner
Â
Â
Kind regards
Philip Lochner
Posted by email.
-----Original Message-----
Sent: 13 March 2006 04:31 AM
To: megasquirt2@msefi.com
Subject: MSII V3 Build Questions
Personally I bought the MS2 harness from Jerry. All of his wires are 18AWG by the look of them and the tach input is even a nice shielded wire. Saves a helluva-lot-of-time!!!
This post is at: http://www.msefi.com/viewtopic.php?p=107365#107365
