Supercharged advTable1.vex files
SCIROCCO53
Post by SCIROCCO53 »
Does any body have a *.vex files for timing on a supercharged engine to share??
WV 1900cc MSnS-E Eaton
2screwed
Post by 2screwed »
This .vex is for a 355 chevy. Victor Jr heads, 7.8:1Cr. Tested up to 160kpa on 98RON.
Per, I saw your PM but was not able to attach anything so you have it here instead.
Lars
SCIROCCO53
Thanks, Lars :RTFM:
1.9 supercharged Scirocco MKI, MS-I/MSnS-E V3 Extra029q2 code
http://www.scirocco53.net
olsteve
Post by olsteve »
That looks like the VE table. I think he wants the timing table.
boost junkie
Post by boost junkie »
Turbocharged 2.0L 4 banger.
Ive only run it to 200kpa so far but there's no detonation on 93 octane pump gas...
-shawn
msns-e controled turbo neon
sample msq's!
2screwed
Post by 2screwed »
olsteve wrote:That looks like the VE table. I think he wants the timing table.
It is my timing table. I'm no expert, but I think the numbers in the advance table .vex are "raw" 0-255 corresponding to -10 to 80 degrees. If you open it as a text file the numbers make no sense.
Lars
