VE Table Generator
Ve Table Gnerator
am having a problem with the VE table generator in MT 225 and the online generator and megasquirt.info.
Both tables report errors when i attempt to generate the VE table.
Torque at Maximum Hp (193.3) is greater than peak torque (177)
I am using the following information.
displacement 170
torque 177 @ 3000
hp 184 @ 5000
idle 650
redline 5500
what am i doing wrong here?
jeff
Ve Table Gnerator
Recall HP = Torque*RPM/5250
If you have 184 horsepower at 5000 rpm, you have 184*5250/5000 = 193 ft·lbs of torque, which is obviously higher than your 'peak' of 177 ft·lbs.
This means the 177 can't possibly be the peak, since it is even higher at 5000 rpm. The error message is alerting you to this.
So I think either your HP or torque number aren't quite right. They may have been 'adjusted' in some way, or they may be 'marketing' numbers rather than 'engineering' numbers.
panel
Ve Table Gnerator
I always have probs with this too. I still can't do it?! Good info!lance wrote:
Ve Table Gnerator
of course, nothing coompares to a rolling road!
Ve Table Gnerator
Im useing Dyno numbers + 15% drive train loss to calculate crank numbers,,
Dyno = 171whp @ 4900 rpm
Torque = 159wt @ 4600 rpm
Idle = 500
redline = 7000
2.5 liters
Calcs are 201 crank hp and 187 T.
according to the equation HP= T*RPM/5250, this doesnt compute...
any input?
Jason
96' Ford Probe GT
KL-ZE Swap
Garrett TO4B
Ve Table Gnerator
Roger
Ve Table Gnerator
96' Ford Probe GT
KL-ZE Swap
Garrett TO4B
Ve Table Gnerator
They Dyno sheet I have has a comparison run against it, and the colors on the 2 runs are swapped. When I first posted, I was looking at the wrong lines and posted 2whp numbers...
Problem solved,
VE Table generated
EVEME 1.0
UserRev: 1.04
UserComment: Automatically generated
Date: 10-20-2004
Time: 22:59
Page 0
VE Table RPM Range [ 8]
[ 0] = 4
[ 1] = 9
[ 2] = 19
[ 3] = 29
[ 4] = 40
[ 5] = 50
[ 6] = 60
[ 7] = 70
VE Table Load Range (MAP) [ 8]
[ 0] = 20
[ 1] = 30
[ 2] = 45
[ 3] = 55
[ 4] = 65
[ 5] = 80
[ 6] = 90
[ 7] = 100
VE Table [ 8][ 8]
[ 0] [ 1] [ 2] [ 3] [ 4] [ 5] [ 6] [ 7]
[ 0] = 26 26 35 53 64 67 64 61
[ 1] = 26 26 37 56 68 71 67 64
[ 2] = 26 26 41 62 75 78 74 70
[ 3] = 26 26 43 65 80 83 79 75
[ 4] = 26 26 46 69 84 88 84 80
[ 5] = 26 26 49 75 91 95 90 86
[ 6] = 26 26 52 78 95 99 94 89
[ 7] = 26 26 54 82 100 104 99 94
Jason
96' Ford Probe GT
KL-ZE Swap
Garrett TO4B
