engine acts like rev limiter on CBR600 FSAE car
Posted: Tue Jun 07, 2011 10:27 am
So we have a CBR600RR running Microsquirt for an FSAE car. It has a gt12 turbo and is running E85 fuel. We have a GM type 3 bar map sensor and an innovate wide band and used it to help with the autotune feature.We had a horrible time getting it to run right with the factory COP setup so we stuck LS1 coils on it and it is much better. It will start and run ok but the two main probs we have are as follows;
It doesn't want to idle below 2000rpm. We do have some custom bigger cams in it so I expected it to be a little finicky but it basically shuts off if you get it below 2k. We are just running the throttle blade - no idle air motor. I tried varying the injector pwm from 45 to 90 with very little difference in quality.
The main problem is it won't rev above 5700rpm. I've tried a number of things and it just acts like a rev limiter there. Attached is the latest msq and a datalog where you can see me slowly revving it up and see it just freak out at 5700.
Any ideas?
Any ideas?
