Tooth Wheels 6 + 1 tooth cam every 720°
runblade
Post by runblade »
Can microsquirt module recognize a 6 teeth wheel plus a cam with 1 tooth every 720°.
Re: Tooth Wheels 6 + 1 tooth cam every 720°
It can if the 6-tooth wheel is on the crank. You have to put it in dual spark mode by selecting either rising or falling edge cam sync. Then enter 0 missing teeth. Set skip teeth = 2 x 6 / no_cylinders and this must come out as an integer - no fractional part.
runblade
Post by runblade »
Yes, the 6-tooth are on crank wheel! :yeah!:
Today I order a Mirosquirt Module.
Many thanks Mr grippo for your fast reply.
