self tune?
self tune?
- Site Admin
Re: self tune?
Automatic Mixture Control is in the V2.8xx code, see:65looter wrote:Can or will the Microsquirt provide a self tune option in the future?
http://www.megamanual.com/ms2/amc.htm
All of the base code functionality for MicroSquirt/MS-II is listed here:
http://www.megamanual.com/mt28.htm
kib_norway
Re: self tune?
I see when connected to PC/MT that the ego correction does a whole lot of work - however, after riding quite a long ride, and then reconnects to MT and does a "fetch" of my VE, it still is unchanged.
The settings are (if I remember right)
FLASH Update on
Step Size (%): 10
Minimum VE Change (%): 1
Vertex Tolerance (RPM): 300 (My rpm bins are spaced by 600 rpm steps)
Vertex Tolerance (kPa): 10 (My MAP bins are spaced by 5 and 10 kpa steps)
Table Change Interval (sec): 5
Flash Update Interval (sec): 15
Update After (events): 2
Now... what would it take for this setup to make changes to my VE table? I am quite sure that I am not on WUE (i have leds to indicate wue and accel enrich) and the accel enrich goes on for just blinks at a time.
Are there other settings somewhere I need to activate to make this self tune?
Please advice
Re: self tune?
kib_norway
Re: self tune?
kib_norway
Re: self tune?
Here is the msq. Let me know if it makes sense...
I have 3 possible theories:
1. For how long time should one have to drive with the self tune to flash activated before seeing any changes? I have driven approx30 mins only...
2. If the values in the VE table is to far out for the EGO correction to be able to correct it- will it still try to update the VE table inthe right direction? I.e. if EGO correction is limited to 50%, and the VE is 60% rich, will the self tune to flash still try to lean out VE value?
3. - and - just one thought - if there are comm problems between MT and US when fetching a table, would I get an error message? I have a prolific usb/serial converter, and I've read here that these can be tricky... will buy a pcmcia serial port tomorrow...
BTW, the bike allready seems way stronger in the midrange than it was with the carb - and it's still not tuned in. Very good!
- Attachments
- megasquirt200905272120.msq
- (25.07 KiB) Downloaded 79 times
Re: self tune?
Ego must be in closed loop, which itself requires a bunch of conditions as shown in the second code snippet.
// check criteria for being in AMC mode
if(ego_cloop && (bad_ego_flag < 3) && (outpc.warmcor == 100) &&
(outpc.tpsfuelcut == 100) && (outpc.tpsaccel == 0) && <-------- no decel/ accel
(outpc.fuelcor == 100)) { <------ no flex fuel corr
if( (inpram.EgoOption == 0) || <------- criteria for NOT being in ego closed loop
(outpc.rpm < inpram.RPMOXLimit) ||
(outpc.engine & 0x30) || // engine accel/ decel
(outpc.clt < inpram.EgoTemp) ||
(outpc.tps > inpram.TPSOXLimit) ||
(outpc.kpa > inpram.MAPOXLimit) ||
(outpc.seconds < 30)) {
outpc.egocor1 = 100;
outpc.egocor2 = outpc.egocor1;
// get ego1,2 from sensor
switch_page(1,5,6); // get_adc
ego_cloop = 0;
egopstat = 0; // out of ego closed PID loop
goto EGO_RETURN;
ego_cloop = 1;
kib_norway
Re: self tune?
I have been riding 150-200 km, and I now see that the VE map updates at some bins. So - it works.
However, what if the VE map at some pints are way off, so that the ego correction (50% or 80% or whatever I set it to) do not manage to the correct AFR properly?
Will the self tune lean out the VE map when this happens, or will it just ignore those places in the map, since the ego correction is "out of range"?
Re: self tune?
But I would never just blindly tune to an AFR target table. Where did you get it ? How do you know it is right ? How do you know that whoever generated the table had the same objectives you have ? Some people want performance, some economy, some emissions, some just smooth riding. You should bring your table in manually the way you want it, then the ego values at those points become your AFR target table. Then you can use self tune every once in a while to keep your engine there.
You should not have flash update on all the time. There is a limit to how many times you can burn flash (somewhere between 10K and 100K times) so if you had a very fast update rate with only a small change in ve required, and a jumpy ego readback, you could in theory do 1000s of burns in a few weeks.
