low impedance injectors
Posted: Sat Aug 12, 2006 2:03 pm
by Dave Sloan
I have just read that hte microsquirt will only run 1 low impedance injector per bank, for bikes with 4 low imp injectors is it possible to run resistors or a flyback board with 2 low imp injectors per bank?
Dave
Re: low impedance injectors
Posted: Sat Aug 12, 2006 4:13 pm
by Bruce Bowling
Dave Sloan wrote:I have just read that hte microsquirt will only run 1 low impedance injector per bank, for bikes with 4 low imp injectors is it possible to run resistors or a flyback board with 2 low imp injectors per bank?
Dave
Hi Dave,
The drivers on MicroSquirt will current limit at 5 amps, so you would need to run series resistance with each injector in order to keep the overall current draw below 5 amps per bank. So if you were using two injectors per bank the injector resistance plus the series resistance should be below 2.5 amps per each injector branch.
Posted: Sun Aug 13, 2006 12:35 am
by Dave Sloan
Thats great, thanks Bruce
Dave
Posted: Thu Sep 07, 2006 2:58 am
by astrolt
does anyone have any impedance specs on any M/C injectors?
