AFR tables?
phongshader
AFR tables?
Do I create a table with entries that more or less conform to "Conventional wisdom (not always right) suggests that you tune for ~13.1:1 at peak torque, and 12.5:1 at peak power for a naturally aspirated engine." and try to achieve those targets by setting ego control percentages or autotune?
Re: AFR tables?
Pretty much.phongshader wrote:I'm a little confused about how I use/tune/generate an AFR table for MS2.
The VE that was generated was approximately 10% richer in all areas. I mannually tuned all the cells slowly. Idle cells, partial throttle, full boost maps etc.......
I just installed my LC1 and I am going to see if I can fine tune it a little further using autotune.
I am following conventional wisdom on what values to use for my AFR tables. I have a good idea of what AFRs I need to run as I spool up my turbo and go flat out at full boost.
So I am curious to see how well autotune pulls the values tighter inline with what I want.
Should be interesting.
I am going to run autotune first........
My Success Story
phongshader
Olds 215 v8 in a '59 Alfa Romeo Spider 2000
phongshader
What should ego control percentage be set at? Or better yet, what would be the ideal settings in Megatune to take full advantage of Auto Tune?
cossie_storm
phongshader
