V2.21 board - Direct Coil driver
hippled
Post by hippled »
Hello
I am converting my stock 4.2L jeep YJ to feul injection iwht MSII. I have everything done except the ignition. I bought my board before i decided to do spack aswell. Is there any way i can use the V2.21 board to drive the coil directly. Or if not what is the simplist way to drive the coil with MSII V2.21 with a modules?
Dave
bleoh
Post by bleoh »
In the MSII manual under ignition control is a section about how to use various modules with MSII. Below is a link to the GM section (hope the link works).
http://www.megamanual.com/ms2/GM_7pinHEI.htm
Good luck. Brian.
MS2 v3.0 MT2.25 controlling 6 high z injectors and ignition
hippled
Post by hippled »
Thanks I have already pick ones of those up. I figured after a bit more reading that was the way to go.
