for those of you with air cooled engines....
Posted: Tue Nov 30, 2004 12:43 pm
flyguyeddy,
I put a simple BOSCH water ccolant sensor in the heat exchanger nearest to cylinder (Citroën 2CV). Max temperatur is not more than 70°C.
http://megasquirt-de.serviceline.ch/suc ... r-mini.jpg
This place is good for coldstart warm up enrichment but not perfect for fastest response when you'll use it as gauge for danger driving conditions. The time delay is 5 to 10s.
Another slight disadvantage is maybe that it cools faster down than combustion chamber. --> The priming pulse is not perfect.
I guess best allround place is at cylinder head (fin) near exhaust valve: Representive starting temperature and short delay for warm up and extreme hot peaks.
»Horst
»Horst
