Single Vs Dual Table
Mad Professor
What is the point of this Single or Dual Table?
Is it just so I have have a bigger RPM range?
i.e going from: (Table 1) 600,1100,1500,2000,2500,3000,3500,4000,4500,5000,5500,6000
to: (Table 1) 800,900,1000,1100,1200,1300,1400,1500,1600,1700,1800,1900
(Table 2) 2000,2500,3000,3500,4000,4500,5000,5500,6000,6500,7000,7500
Or have I got the wrong end of the stick.
Thanks for your time.
So PW1 = PW2
As I understand, the second table would mainly be used for staged injectors (more than one injector per cylinder). Were you might want a second set of injectors at high power for example.
I suppose if you had a two cylender engine you could also tune each cylinder to its own VE table. Or perhaps on a "V" engine with seperate manifolds you would use it... but I'm just a wimpy 4-banger so can only speculate. I though of using it to inject methanol/h2o at high boost... when I think the bottom end can take it
efahl
- Site Admin
If you want a greater spread of RPM on one VE table, just change the RPM bins, I really can't see having bins 100 RPM apart, that would just be a nightmare of tuning, with no real benefit.
Eric
darkstarmedia
Richard
DarkStar Media LLC
Inline Idle Air Control Valve Housings now availible through Jerry at DIYAutoTune.com
jsmcortina
- MegaSquirt Guru
It is true that this is what the Extra code does, but I forget why it requires DT to do it. Surely we could apply ego correction differently to channel 1 and channel 2? (I ask in a semi-rhetorical manner)darkstarmedia wrote:Is is also handy (As I understand it) to run engines in a 'V' configuration with 2 oxygen sensors. one table controls one bank using one O2 sensor while the second table is used to control the second bank with the second O2 sensor.
efahl
- Site Admin
James,jsmcortina wrote:It is true that this is what the Extra code does, but I forget why it requires DT to do it. Surely we could apply ego correction differently to channel 1 and channel 2? (I ask in a semi-rhetorical manner)
I'm guessing that the reason for having two sensors is because the two banks need a different tune. If that's the case, then you'd want dual tables to set the base for each bank differently, and not make one lambda correction do all the work of trimming out the one "off" bank...
Eric
