How can I tell what coil pack I have?
panel
Post by panel »
I have a Subaru EJ20 Turbo with a coil pack on the intake manifold. Has no ignitor attached to it. Can this be run by the Microsquirt with some mods to it?
My VW Bus and MS pix CLICK
Running on MS since July 22/05
MSnExtra July/06 EDIS Aug/06
panel
Re: How can I tell what coil pack I have?
Post by panel »
Is the top image(green check mark) a view from the side of a standard 4 terminal coil pack?
No such thing as a 'standard 4 terminal coil pack'; they're all different ...
A quick check of Google and eBay suggests the EJ20 uses either a 4-tower pack with a 3-terminal connector on a lead, or a set of 4 COP, each with a 3-wire connector (either close-coupled or on a lead). I'll assume you have the single 4-tower pack. IF you have an older uS with the side-mounted connector and a metal enclosure, you can drive the coil pack directly. If you have the newer V3.0 with the connector on top of a plastic housing, you need an external ignitor, whether DIY's QuadSpark, a Bosch ignition module, or similar.
panel
Post by panel »
I think mine is a 4 wire. Would this have a built in ignitor then ?
panel
Post by panel »
I'll try to get a pic of the actual plug end but for now...........
panel
Post by panel »
Got a MS2 on the way instead of the Microsquirt...........will post over there now.
http://www.msextra.com/forums/viewtopic ... 01&t=63774
