Coil on plug driver for v3.0
cruiserbrett
The information supplied for the v3.0 microsquirt seems to be lacking any info for setting up a coil on plug driver for electrically challenged folks like me. Its great at selling the LS1/2 coil near plugs, but I would love to see a schematic. Searching BIP373 show little for the v3.0...
I did order a pair of the BIP373 from diyautotune.com when I purchased the microsquirt a few weeks ago.
Can I get away without the supplied 330 ohm resistor?
What do I need to do to set the output correctly in the software?
Since the coils are 2 wire, there is no ignitor present, so I am guessing I have to set dwell etc on the software? I am not sure if I am correctly describing things, but do I need to account for any "latency" present in the BIP373 when setting this sort of thing?
If I source a replacement terminal for the AMPSEAL connector, can I replace the unusually heavy gauge IGN OUT wire since I am driving the BIP373 at logic level? Seems to be a carryover in harnesses from previous versions that I was surprised to see.
I do plan to pot the BIP in a small enclosure with a tiny heatsink, so that it will be water resistant for use in the dirtbike environment. Am I asking for trouble?
thanks in advance for the help!
cruiserbrett
Re: Coil on plug driver for v3.0
I guess I am not asking the question properly:
How can I drive a single coil on the v.30 microsquirt? I am interested in building a small external(eventually potted) ignition module and have the bip373. the engine is intially going to be M-N wheel without a second input(no cam sensor) and its single cylinder, and the referenced below doc states I need to tie outputs 1 & 2 together?
Since tying the pair of outputs together at the ignition module would be easiest, can someone suggest a schematic to do that, and incorporate the bip373
The useasydocs http://www.useasydocs.com/details/dualspark.htm link mentions a vb921 coil driver, but why is that mentioned on v3 documentation? Its missing from the newest version correct?
I am completely baffled by this aspect, so any help would be greatly appreciated.
http://www.thumpertalk.com/topic/761641 ... n-project/
He also posts on this forum, search author mxrob.
A lot of good information on MSing single cylinder bikes.
One question, what have you got against using an LS1 coil. Every thing you need in a package that is about the same size as a motorcycle coil.
cruiserbrett
I was hoping to drive a coil that required less current draw in comparison to the LS1/2 series... With the charging system of the DR350 good for maybe 175W, a coil that didnt draw too much amperage at higher rpm is desired.
- Master Squirter
DonChicago48
"Your V3 MicroSquirt® controller can only supply a logic-level output. It will not directly control a coil, for example.
What this means is that the V3 MicroSquirt® will provide a 0-5 volt signal output of low current which is then used to trigger an external driver module. The MicroSquirt® documentation outlines several driver modules that can be used and how to hook them up. You can also use external BIP-373 drivers on your own board to drive the coils. The new ignition coils with the built-in igniters (like the LS1/LS2 coils) work great and really make the installation robust and easy."
In another place (the Dual Spark documentation for the newer V3 version, it shows a 7.5 Amp coil directly connected to the MS IGNOUT connection. My only guess is that this document was edited from an earlier version.
I went to the diyautotune site and checked the MS description. it clearly states:
"•Logic level ignition outputs only - coil drivers have been removed."
So I also bought a couple Bosch 124 Igniter modules to drive my dual 3-Ohm Dynatek coil. If I didn't already have the coil and mounting bracket for my Harley, I'd go with the GM LS1 or LS2 coil mentioned in the MS QuickStart guide.
