After a couple of Drag strips, the Q1 transistor blew out.
hzdistributor
The engine is a 2.0l 8V Turbo Engine in a Full chassis car running 9.67 in the 1/4mile.
jsmcortina
- MegaSquirt Guru
With the V2.2 board you will need the flyback board to reliably drive those injectors. This is a known failure mode and has been addressed in the V3.0 board.
Check out the flyback section of the megamanual.
boost junkie
racingmini_mtl
You can use these with any code be it the standard code or the high-res code. I agree with boost junkie that the high-res code would be a good choice for you.
Jean
hzdistributor
