GM DIS questions
flyguyeddy
flyguyeddy
jsmcortina
- MegaSquirt Guru
If those are the only two functions you need from the old ECU that is.
flyguyeddy
i used the factory ignition module in the wheelwell. i removed the signal for reference pulse from the mocule thats controlling the ignition to the ECU and ran it JUST to the megasquirt and grounded the low line. (just like it shows for GMDIS setup pages) i then ran all the wires from the factory mocule to the ecu and pigybacked the VR sensor wires so that it would have a sensor signal from the crank. works like a charm.
