Distributor + MS spark control
Zendalar
Post by Zendalar »
Is it possible to tune the car with distributors vacuum line connected?
I just want to tune the car to work so that the idle is most stable. I want to leave the rest for the distributor's vacuum+centrifugal "system". So basically i want to use the MS to control ignition under 1000RPM.
Any advice on setting the table right?
jsmcortina
Post by jsmcortina »
This is not a good idea. Either have the distributor control the timing or have Megasquirt control the timing, not a bit of both.
