Tuning Alpha-N
Posted: Thu Sep 16, 2004 4:09 pm
For those that may be interested, I have added a "Tuning with Alpha-N" section to the manual. It is here:
http://www.megasquirt.info/manual/mtune.htm#alphan
As always, comments, corrections, and additions are welcomed.
Tuning Alpha-N
Posted: Thu Sep 16, 2004 7:22 pm
by Flatline_Racing
Am I correct in assuming that Speed Density would still be best for a turbo strip vehicle?
Tuning Alpha-N
Posted: Fri Sep 17, 2004 2:50 am
by Karl_Skewes
sure. .. SD is best.
I like TPS accelleration enrichment too, but the MAPDot code is very cool, just started messing with it today.
Tuning Alpha-N
Posted: Fri Sep 17, 2004 3:03 am
by OneSlow73
great little guide on alpha-n lance, i plan to use it on my ms project im puting together...465"bbc with more dur at 050 than most would believe for adv.
Tuning Alpha-N
Posted: Fri Sep 17, 2004 7:48 am
Yes, with boosted engines, you MUST use the speed density algorithm with MegaSquirt, because the throttle position bears little relationship to the amount of air going into the engine.
Tuning Alpha-N
Posted: Mon Dec 06, 2004 12:06 pm
by future
lance wrote:Yes, with boosted engines, you MUST use the speed density algorithm with MegaSquirt, because the throttle position bears little relationship to the amount of air going into the engine.
And what do you think about the hybrid alpha-n VE(tps,rpm)*MAP?
I wonder if it delivers the correct fuel.
Re: Tuning Alpha-N
Posted: Mon Dec 06, 2004 1:20 pm
by Bill Shurvinton
Depends how well you tune it. In UK, most aftermarket stuff is tuned AN
and runs well. Until you go up a mountain...(sorry in joke over here)
>To stop getting all MSEFI messages, email us at
spam_complaint@msefi.com and we will remove you ASAP.
Tuning Alpha-N
Posted: Mon Dec 06, 2004 10:07 pm
by Tortfeaser
lance wrote:As always, comments, corrections, and additions are welcomed.
Just a question - why was this (below) done?
In V3.00 embedded code the fuel equation (minus the enrichments and open/close time) looks like:
PW = Req_Fuel * tps * VE(tps,rpm)
as opposed to V2.xxx code, which looked like this:
PW = Req_Fuel * VE(tps,rpm)
Note the extra factor of TPS (in red) in the V3.000 code.
