GM V6 DIS wiring
tedbrown
GM V6 DIS wiring
Post by tedbrown »
I have been running EFI/DIS on a Corvair (www.corvair-efi.com) for years with my GM OBD-1 Computer. I wanted to go to a easier computer and it would also allow the Corvair Community to have a self programmable computer. I was assured that no issues would be encountered except that the idle (stepper IAC) would not be supported. I like the system layout, size, etc, but my big problem is the 4 wires for the control side of the DIS. It would be the same setup as the 7/8 pin GM for distributor operation. This is wasted spark and controlled by DIS ignition module.
The problem is I see so many different wiring diagrams on the forums. There is only one correct answer.. guessing does not work and even the manual says wiring has not been confirmed. Grounding the Reference Low as some diagrams show is not the answer as "The General" would have grounded at the DIS. I also know that some would say switch to Ford EDIS, but we already have 7x wheels made and it really works well as designed.
Does anyone here use a GM V6 using wasted spark coil pack as designed (7x trigger wheel) in there setup with a Microsquirt? Again, I know there are some wiring diagrams on the forum, but I know I not the only person to ever try GM Wasted spark or 7/8 pin.
These are the 4 Wires GM DIS:
EST:
Reference:
ByPass:
Ref Low:
Thanks for the help in advance.
Ted
Anderson, SC
Ted Brown
www.Corvair-efi.com
Anderson, SC
61 Corvair Loadside Pickup (EFI)
68 Corvair Monza Convert (EFI)
ScottyDont1987
Re: GM V6 DIS wiring
Post by ScottyDont1987 »
Did you ever get this figured out. I am running into the same problem.
Last edited by ScottyDont1987 on Fri Jun 09, 2017 2:06 pm, edited 1 time in total.
ScottyDont1987
I am wondering the same thing. I have seen wire diagrams for Mega but not Micro. I can't get my car started and have been searching for about 2 weeks now for a solution.
tedbrown
Post by tedbrown »
Finally. Matt Helped, but my crank sensor position is much different than the manual, even reversed rotation (Corvair). I had been running a GM 16196395 ECM modified with tunerpro for my Corvair Project. Appears to be same settings as GM HEI, but I will update more tomorrow.
Weatherpak pins are alpha
GM Color: Purpose: M/Squirt Pins
A Tan Bypasss INGOUT2 11
B White EST INGOUT1 12
C Blank
D Variuous Tach To Dash Tach
E Purple Ref High VR- 33
F Red/Bll Ref Low Sensor Gnd 18/20
Ted Brown
www.Corvair-efi.com
Anderson, SC
